November 1, 2017 at 3:05 pmJALIL KHANSubscriber
I am simulating flow over a bullet . What boundary condtitions should i use.
November 1, 2017 at 3:16 pmRaef.KobeissiSubscriberHello Jalil You need to use the Far Field boundary condition and specify the Mach Number appropriately. Also, I would chose the density based solver and have Air set up as ideal Gas.
Cheers
- The topic ‘FLUENT- Fluid Flow over bullet’ is closed to new replies.
Ansys Innovation Space
- How do I get my hands on Ansys Rocky DEM
- Non-Intersected faces found for matching interface periodic-walls
- Unburnt Hydrocarbons contour in ANSYS FORTE for sector mesh
- Help: About the expression of turbulent viscosity in Realizable k-e model
- Script Error
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Facing trouble regarding setting up boundary conditions for SOEC Modeling
- convergence issue for transonic flow
- Running ANSYS Fluent on a HPC Cluster
- Point exception in erosion calculation
802
599
591
366
