Electronics
Electronics
PEmag Script Error 80070213 while Writing fields for 3D FEA model
    • bram.oudeaarninkhof
      I have constructed a planar transformer using PEmag, of which I was able to generate a 2D FEA model. However, when I now try to generate a 3D FEA model I get the following error when the process reaches 'Writing Fields'.
      Ansys Electronics Desktop Version 2022.1.0, Build: 2021-11-22 22:18:25
      Location: C:\Program Files\AnsysEM\v221\Win64\ansysedt.exe
      Description: Error in performing operation.
      Line(40):  "    oModule.CalculatorWrite "J" + CStr(w1 + 1) + "_" + CStr(f + 1) + ".reg", _"
      [Exiting application]
      -- Message Window --
            *Global - Messages
              [error] Script macro error: Script Error (Code 80070213) in file:  C:/[...]/PEmag_ER237.pjt/WriteFields.vbs Description: Error in performing operation. Line(40):  "    oModule.CalculatorWrite "J" + CStr(w1 + 1) + "_" + CStr(f + 1) + ".reg", _"
      I looked into the Help functions of PEmag and browsed the internet to find a solution, unfortunately to no avail. Let me know how I can prevent this error from occuring.
      Thank you in advance!
    • HDLI
      Hello bram.oudeaarninkhof,
             Could you try an exmaple in C:\Program Files\AnsysEM\v221\Win64\UPM\Examples\PEmag\ ?
             Could you run vb scripting? It seems you might not run the vb scripting.
             I also suggest to do perfect installation of EM suite (AEDT).
             1). uninstall AEDT completely, and restart computer
             2). Turn off anit-virus and firewall, or other policy to block the installation
             3). "Run as administrater" to install AEDT
             4). Turn on abti-virus and firewall.
      HDLI
    • Kili
      I got the same error and that, even with a perfect installation
    • HDLI
      Hello Kili,
             What is the error message?
      HDLI
      • Kili
        Hello, the problem is solved, I needed more space on my hard drive. Thank you :)
  • The topic ‘PEmag Script Error 80070213 while Writing fields for 3D FEA model’ is closed to new replies.
