May 9, 2022 at 11:21 am
AnttiP
SubscriberHi,
I have been working on PCB design with SIwave and I have a recurring problem where suddenly the circuit editing tools get disabled and I can't figure out how to re-enable them. When I reload the model they'll work a while and then get disabled again at some point.
Here's an screenshot of the top ribbon with the Circuit Elements and Draw Geometry greyed out:
May 31, 2022 at 6:18 pmPraneeth
Please provide more information about your issue to help us serve you better.
May I know if this happens for every design or any particular design?
All the very best Praneeth.
January 10, 2023 at 9:03 amamer.mesic
SubscriberHello,Â
I have the same issue. I am not able to place circuit elements or draw geometry in any of my SIwave files. I am using 2022R2 version of SIwave thou.
Did you find a fix for this issue?Â
January 10, 2023 at 9:07 amAnttiP
SubscriberYes, you need to have the Top-Down View enabled form the View ribbon. If you rotate the PCB even half a degree those tools are greyed out and you can't use them.
March 3, 2023 at 2:11 am
Christopher LaFave
SubscriberNice! Thank you AnttiP!
January 10, 2023 at 9:09 amamer.mesic
SubscriberIt works now! Thank you for the help, i was trying to find the solution to this for while now!
Viewing 4 reply threads- The topic ‘What disables Draw Geometry and Circuit Elements in SIwave 2021R2 and how to re-enable them?’ is closed to new replies.
5849
1305
