March 10, 2022 at 11:42 pm
Shahzaib
SubscriberHi all,
Actually I have an antenna in HFSS with gain and radiation pattern. I want to include measured SnP file of amplifier with it. what is did is to make a circuit file, export antenna there and attached a port with snp file. but it is not plotting the Radiation pattern.
How can I debug this issue?
Screen Shot is attched.
March 22, 2022 at 11:06 amAncS
You can go through the course Cosimulation Using Ansys HFSS and Circuit - Lesson 2 - ANSYS Innovation Courses. This may help you to achieve what you want.
Hope this helps.
Regards
Anchal
Viewing 1 reply thread- The topic ‘Radiation Pattern Plot in Circuit’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- Y wiring method and the start and end points of winding.
- Lumped Port Deembed
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
Top Contributors-
3882
1414
1241
1118
1015
