Parameterize Springs Stiffness Constants in Mechanical Command Snippet
    • lbtung248
      Hello!
      I am using a torsional spring combi250 and i want to parameterize the stiffness constants K1 to K6. As far as i know, i must assign these constant values to input arguments of the command snippets ARG1 to ARG9. Which command can i use to assign these values?
    • Ashish Khemka
    • lbtung248
      Thank you for your reply, however within the post you referred to, i only find information to assign stiffness coefficients for Element 184 using TBDATA command. I tried the same command for Element combi250 and it didnt work.
      For TBDATA command, my element should be a joint connection type, where as the element i have now is a spring connection. I think that is why it didnt work.
      Do you have any idea?
  • The topic ‘Parameterize Springs Stiffness Constants in Mechanical Command Snippet’ is closed to new replies.
