August 25, 2021 at 7:01 pm
mgjeong
SubscriberAugust 26, 2021 at 8:18 pmANSYS_MMadore
Forum ModeratorPlease share the full error message. The message is cutoff, you can either expand the window or scroll down and take another screenshot.
August 27, 2021 at 12:40 ammgjeong
SubscriberFailover feature 'Ansys electronics_desktop' is not available.
Request name electronics_desktop does not exist in the licensing pool.
Cannot connect to license server system.
The license server manager (lmgrd) has not been started yet the wrong port@host or license file is being used, or the
port or hostname in the license file has been changed.
Feature
electronics_desktop
Server name
129.10.132.63
License path
1055@129.10.132.63;
FlexNet Licensing error
-15,10032
but the license server is working.
August 27, 2021 at 11:23 amANSYS_MMadore
Forum ModeratorPlease run these commands on your local machine and share the full output.
ping 129.10.132.63
ipconfig /all
August 28, 2021 at 4:34 ammgjeong
SubscriberC:\Users\mingy>ping 129.10.132.63
Pinging 129.10.132.63 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 129.10.132.63:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss)
C:\Users\mingy>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : MGWorkstation
Primary Dns Suffix. . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : nunet.neu.edu
Ethernet adapter Ethernet:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix. :
Description . . . . . . . . . . . : Intel(R) Ethernet Connection (2) I219-V
Physical Address. . . . . . . . . : F0-2F-74-1D-F4-CE
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Ethernet adapter Ethernet 2:
Connection-specific DNS Suffix. : nunet.neu.edu
Description . . . . . . . . . . . : Realtek PCIe 2.5GbE Family Controller
Physical Address. . . . . . . . . : F0-2F-74-1D-F4-CD
Link-local IPv6 Address . . . . . : fe80::dc6e:9f97:f705:8158%13(Preferred)
IPv4 Address. . . . . . . . . . . : 129.10.135.203(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.252.0
Lease Obtained. . . . . . . . . . : Wednesday, August 25, 2021 8:24:56 PM
Lease Expires . . . . . . . . . . : Saturday, August 28, 2021 2:24:53 AM
Default Gateway . . . . . . . . . : 129.10.132.11
DHCP Server . . . . . . . . . . . : 155.33.2.129
DHCPv6 IAID . . . . . . . . . . . : 284176244
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-28-B7-5C-96-F0-2F-74-1D-F4-CE
DNS Servers . . . . . . . . . . . : 155.33.2.1
155.33.2.2
NetBIOS over Tcpip. . . . . . . . : Enabled
Wireless LAN adapter Wi-Fi:
Description . . . . . . . . . . . : Intel(R) Wi-Fi 6 AX200 160MHz
Physical Address. . . . . . . . . : DC-41-A9-BA-00-09
Wireless LAN adapter Local Area Connection* 1:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Physical Address. . . . . . . . . : DC-41-A9-BA-00-0A
Wireless LAN adapter Local Area Connection* 2:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
Physical Address. . . . . . . . . : DE-41-A9-BA-00-09
Ethernet adapter Bluetooth Network Connection:
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
Physical Address. . . . . . . . . : DC-41-A9-BA-00-0D
August 30, 2021 at 11:47 amANSYS_MMadore
Forum ModeratorThis shows you can't ping the server, which will prevent license access. Perhaps PING is disabled, can you open Windows Powershell and run this command and send the output?
Test-NetConnection 129.10.132.63 -Port 1055
August 30, 2021 at 6:53 pmmgjeong
SubscriberPS C:\Users\mingy> Test-NetConnection 129.10.132.63 -Port 1055WARNING: TCP connect to (129.10.132.63 : 1055) failedWARNING: Ping to 129.10.132.63 failed with status: TimedOut
ComputerName: 129.10.132.63
RemoteAddress: 129.10.132.63
RemotePort: 1055
InterfaceAlias: Ethernet 2
SourceAddress: 129.10.135.203
PingSucceeded: False
PingReplyDetails (RTT) : 0 ms
TcpTestSucceeded: False
It seems that the connection is prevented by something.
How could I fix this issue?
August 30, 2021 at 7:10 pmANSYS_MMadore
Forum ModeratorThis is something you would need to work with IT to resolve. There are likely firewalls in the way, or other network restriction preventing access.
September 2, 2021 at 2:54 pmmgjeong
SubscriberI got this from the IT team.
I reviewed the steps that were taken with Ansys. Since both devices are on the same network, there is no firewall in between. Most likely, there is a local firewall on your new ansys server that needs to be modified to allow the trafic.
September 2, 2021 at 3:11 pmANSYS_MMadore
Forum ModeratorPlease see this video for adding firewall exceptions on the license server machine.
http://storage.ansys.com/doclinks/videos.html?code=ConfigFirewallExc-VLU-M2a
September 2, 2021 at 8:34 pmmgjeong
SubscriberNow it work! thank you very much!!
January 26, 2022 at 7:38 pmmgjeong
SubscriberI am trying to access the license server we set.
However, when I start Ansys Electronics Desktop, it shows this error message.
Feature
electronics_desktop
Server name
129.10.135.63
License path
1055@129.10.135.63;
-15,10032
I also did the ping test.
RemotePort: 1055
TcpTestSucceeded : True
I also did
things shown in the webpage.
Could you let me know how to solve this problem?
February 17, 2022 at 12:43 pmANSYS_MMadore
Forum ModeratorPlease make sure the port for the ansyslmd daemon is open on the license server firewall. You can set ansyslmd to a static port by adding it in the license file on the VENDOR line.
For example:
VENDOR ansyslmd PORT=1056
Viewing 12 reply threads- The topic ‘Installed license to a new server and I see license failure message when I install.’ is closed to new replies.
6450
