August 4, 2021 at 8:03 pm
jpg
SubscriberHi,
I was given a license address by our UCSD system administrators to access the campus ansys license . I set the environment variable ANSYSLMD_LICENSE_FILE to ",[email protected]" but I when I launched fluent I got the following error message:
ANSYS LICENSE MANAGER ERROR:Failover feature 'CFD Solver - Level 2' is not available.
FLEXlm server is not responding. Resource temporarily not available.
ANSYSLI_SERVERS: [email protected]
FLEXlm Servers: [email protected]
Hit return to exit.
Unexpected license problem; exiting.
The fluent process could not be started.
Thanks,
Jerry
August 6, 2021 at 6:04 pmmrife
Ansys EmployeeThis does not seem to be an license access issue - from your (client) side communication happened with the license server. It, the license server, was not able to provide the license requested. Please bring this to the attention of the UCSD license system administrator. There are several causes for what you describe but it would be prudent to not force you to be the middleman in troubleshooting an admin issue.
Mike
August 9, 2021 at 5:20 pmWaled Raban
Ansys EmployeeHave you tried resetting your User Preferences? go to Start>ANSYS>ANSYS Client Licensing Settings and Reset to Default.
See the last comment from this post for reference: /forum/discussion/comment/107396#Comment_107396
June 28, 2023 at 7:53 pmDevanshi Jain
Subscriberhey jerry, i'm a ucsd student as well, and i can't seem to connect to the ucsd license, could you please share the instructions if possible?Viewing 3 reply threads- The topic ‘Problem accessing ansys license server’ is closed to new replies.
5824
1305
