May 5, 2021 at 11:01 am
yu.zhu14
SubscriberHi all,
My ANSYS worked fine before but I encountered the following error after I restarted my PC (a mandatory restart to update Windows 10):
''Ansys Workbench has stopped working''
I have tried to reinstall the software and delete all the files in the folder %AppData%/Ansys but nothing worked.
I have tried to open both versions of 19.2 and 2020 R2 and the same error appeared.
Any suggestions on this would be appreciated.
Yours,
Yu
May 5, 2021 at 12:16 pmAkshay Maniyar
Can you please check the below link.
/forum/discussion/8662/workbench-stopped-working-after-win10-update
Many solutions are discussed.
Regards amaniyar
May 5, 2021 at 1:30 pmyu.zhu14
SubscriberHi @amaniyar Thanks a lot for your reply and sharing of the link.
I tried the methods suggested in the post but the error is still here.
I think it should be related to my latest updates since it worked fine previously so I deleted my latest update but the error persists.
Any further suggestions would be appreciated.
Yours Yu
May 5, 2021 at 3:53 pmAkshay Maniyar
Can you please check by clearing %temp% files.
Regards amaniyar
May 5, 2021 at 4:58 pmyu.zhu14
SubscriberHi @amaniyar I tried to restart PC again and it finally started working.
Thanks for your help!
Yours Yu
May 6, 2021 at 6:23 amAkshay Maniyar
Its great. It worked for you. You can close the question as it is solved.
regards amaniyar
Viewing 5 reply threads- The topic ‘How to resolve the issue of Ansys stopped working’ is closed to new replies.
5824
1305
