TAGGED: ansys-fluent, error, mesh, spaceclaim, workbench
February 20, 2021 at 10:34 pm
lzhang545
SubscriberHi,
I'm trying to do a parametric study using Fluent. I imported my Solidworks model to Spaceclaim and used the pull function to set up some geometry parameters. My original model works fine and has reasonable results. However, when I try to change the geometry parameters in the parameter set and update the design point, it has an error of 'Model information is incompatible with incoming mesh. Fluent failed to apply some mesh operations'. I noticed that in Fluent whenever there is a change in Mesh, it's pretty easy to get this warning. Is there a way to change geometry parameters without facing this kind of error?
Thanks for your help!
February 22, 2021 at 12:15 pmRob
Forum ModeratorIt means a surface ID has changed. If the mesh is conformal it's fairly uncommon. If the mesh has interface zones the automatic wall creation can return different IDs each time.
February 22, 2021 at 3:30 pmlzhang545
SubscriberThanks for your help, Rob. Yes, I'm getting different IDs for the walls. For example, previously I have wall-17, wall-18, for the new model I have wall-12 and wall-13. Is there a way to solve this issue?
February 22, 2021 at 4:53 pmFebruary 23, 2021 at 6:01 pmFebruary 24, 2021 at 1:43 pmRob
Forum ModeratorIn that case Workbench must take care of that.
Viewing 5 reply threads- The topic ‘Mesh incompatible error when changing geometry parameter in Fluent’ is closed to new replies.
5884
1306
