This lesson covers the application of Ansys in solving thermodynamics problems. It delves into the understanding of processes such as heat transfer, work input, and entropy change in a condenser. The lesson also explains the concept of isentropic efficiency and how to calculate the rate of entropy generation. It uses a practical example of a problem involving saturated water vapor being steadily cooled as it flows through a constant pressure condenser. The lesson further explains how to use steam tables to determine states and how to apply the first law of thermodynamics to solve problems.
00:39 - Process of heat transfer and the isentropic efficiency of the pump
05:54 - Application of the first law for the condenser to determine the rate of heat transfer
10:59 - Calculation of the rate of entropy change in the condenser and the rate of entropy generation
14:26 - Introduction to the eighth problem involving a perfect gas mixture flowing with 5 moles per second
24:40 - Calculation of the mass flow rate of the mixture and the rate of entropy change
- Thermodynamics principles can be used to calculate the rate of heat transfer, work input, and entropy change in a condenser.
- The concept of isentropic expansion can be used to calculate the entropy change across a turbine.
- To understand the processes involved in a thermal problem, it is crucial to accurately calculate the required parameters.
