Extracting Spring Force Results with APDL Commands — Lesson 2
How do you extract spring force and deformation results for springs that are created using APDL commands in Ansys Mechanical capabilities inside Ansys Workbench?
There is a user-defined result option to extract these results. You can use SPRINGF and SPRINGU as expression scoping to result items with an element ID (spring element ID).
Please find a sample attached for your reference.
You can access the relevant files here: Download Files
Download Ansys Student for free here.
