Exporting .cdb File from Mechanical Software Using Command Objects — Lesson 10
How do you export *.cdb files from Mechanical software without solving the case?
From Mechanical software, we cannot directly export a *.cdb file without solving the case. However, you can try this workaround:
1. Insert a command snippet under Analysis Settings. The command to export *.cdb is as follows:
/prep7
cdwrite,all
2. As we are not finishing the /prep7 module, it will give an error and stop the solution. But before that, it will export the *.cdb file in the working directory.
