Difference Between Wall Temperature and Static Temperature
What is the difference between wall temperature and static temperature?
When postprocessing a wall that has a thickness but does not have shell conduction enabled, the Temperature category provides three options. The difference between wall temperature and static temperature can be understood from the explanation of these options as given below:
1. The temperature of the adjacent fluid / solid cells are stored as Static Temperature.
2. The temperature of the wall surface itself is stored as Wall Temperature.
3. The temperature of the surface that is separated from the fluid / solid cells by the wall thickness is stored as Wall Temperature (Thin).
