In 3D analysis, Force and Pressure loads are related to each other. The major difference between force and pressure is how it is applied to the system. Users can select either force or pressure as a way to excite or load the model, however, one might be easier to use and more accurate than the other. The following video will help you understand the difference between forces and pressures.
Video alternativo con audio y subtítulos en español.
Alternative Video mit deutschem Audio und Untertiteln.
Vídeo com áudio e legendas em português do Brasil.
3:04 - Difference in loading direction for Forces vs. Pressures
4:53 - Sign convention for Forces vs. Pressures
6:48 - Load magnitude for Forces vs. Pressures
10:15 - Demonstrating how to apply Force in Ansys Mechanical
12:25 - Demonstrating how to apply Pressure in Ansys Mechanical
15:31 - Demonstrating how to apply directional Pressure in Ansys Mechanical
Download the accompanying geometry and archived files here. Ansys Student can be downloaded for free here.
