Performing a Thermal-Stress Analysis - Lesson 6
In many engineering applications, a mechanical assembly may undergo significant temperature changes. Such changes in temperature produce thermal strains and, under certain conditions, may also generate stresses. The thermal-stress analysis is necessary to evaluate the amount of warpage caused by thermal strains and to prevent failure due to excessive stresses caused by thermal conditions. To evaluate thermal strains and stresses, we may first need to perform a thermal analysis to obtain information on the temperature distribution over the mechanical assembly. In this lesson, we will learn how to import temperature results from a thermal analysis into a structural analysis in Ansys Workbench to calculate the strains, stresses, and other results from thermal loads.
Alternate video link.
Video alternativo con audio y subtítulos en español.
Alternative Video mit deutschem Audio und Untertiteln.
Vídeo com áudio e legendas em português do Brasil.
日本語の音声と字幕付きのビデオはこちら.
Video Highlights:
1:08 - Typical cases of thermal stress
1:43 - Thermal strain equation
2:32 - Constrained vs. unconstrained thermal expansion
5:18 - Sharing model data between thermal and structural using the same mesh
5:47 - Sharing model data between thermal and structural using dissimilar mesh
7:20 - Assigning element orientation for the body with orthotropic material properties
8:14 - Material properties required for thermal stress analysis
9:30 - Setting uniform reference temperature (environment temperature)
9:51 - Setting material-specific reference temperature
11:06 - Importing temperatures from steady-state thermal analysis
11:56 - Importing temperatures from transient thermal analysis
12:19 - Confirm thermal mapping
Simulation Files
Download the accompanying geometry and archived files here. Ansys Student can be downloaded for free here.
