Feature Operations - Lesson 4
Geometry can be created and edited using scripting in Ansys Discovery. We can use scripting operations to mimic feature operations within the software. Say you have a large model assembly, and you don’t want to manually select and edit all the features - You can set up a script to accomplish these operations.
This lesson focuses on scripting commands associated with geometry creation and the movement and position of those created objects. It also includes a workshop to get hands-on experience with feature operations.
The following topics are covered in this lesson:
- Creating a cylinder, cone, and block
- Making copies of an object
- Translating and rotating an object
- Cleaning and simplifying geometry
