Can we perform transient radiation between two bodies that have different initial temperatures? For example, one body at -150 ̊C and the other at 100 ̊C.
Yes, a two-step analysis will be required as we cannot directly provide initial temperature under transient analysis. Please refer to the attachments to access the solution.
You can access the relevant file here: Download File
