Thermal Analysis of Friction-based System Heating — Lesson 8
Are there examples that help in understanding the procedure for frictional heating prediction simulation between rotating or sliding bodies using coupled thermal-structural field elements?
Explore the solution file to learn how to perform a simulation for friction-based thermal analysis.
You can access the relevant files here: Download Files
