Is it possible in Mechanical software to define heat flux on a surface such as a Gaussian function of a spatial coordinate?
Yes, one can define heat flux on a surface as a Gaussian function of a spatial coordinate in Mechanical software by using APDL commands. Explore the solution file below to learn more.
You can access the relevant files here: Download Files
