Premium
Structures
Ansys nCode DesignLife Getting Started
$450.00
2-4 HOURS
SKU: PL-ST-00072 Categories: , Tag:
This course shows the procedure to use the Mechanical Embedded DesignLife UI for Ansys nCode DesignLife. The Embedded UI allows you to set up, solve, and post-process basic stress-life and strain-life fatigue analyses using the Ansys nCode DesignLife solver without leaving the Ansys Mechanical™ structural finite element analysis software environment.
Learning Outcomes:
After completing this course, you will be able to:
  • Describe the end-to-end solution procedure for stress-life analysis with Ansys nCode DesignLife in Ansys Mechanical.
  • Describe the end-to-end solution procedure for strain-life analysis with Ansys nCode DesignLife in Ansys Mechanical.
  • Recognize the importance of several nCode DesignLife solution setup options, including mean stress correction, multiaxial assessment, and load mapping.
Target Audience:
Mechanical Engineers, including Vibrations Engineers, Dynamics Engineers, Aerospace Engineers, Automotive Engineers, and most other subdisciplines; Mechanical Design Engineers; Mechanical Designers.
Prerequisites:
  • Ansys Mechanical Getting Started: Basics course.
  • Concepts of Fatigue Analysis course (Optional).
Please note:
These training materials were developed and tested in the 2022R1 release.
    $450.00
  • Course Duration: 2-4 HOURS
  • Skill Level: Beginner
  • Skills Gained: Stress-Life Analysis, Strain-Life Analysis, Time Series Loading, Elastic-Plastic Correction, Load Mapping
