Premium
Electronics
3D Layout GDS Import and Analysis with Ansys HFSS Software (Workshop)
$450.00
1-2 HOURS
SKU: PL-EL-00018 Categories: , Tag:
This workshop demonstrates the import of a GDS file of an interposer structure into the IC mode of Ansys HFSS 3D Layout in Ansys Electronics Desktop (AEDT)™ electronics systems design platform. You will learn to use control files to assist the GDS import as well as how to set up the model for simulation.
Learning Outcomes:
  • Step through a typical GDS import process.
  • Understand the basics of .map and .xml control files to assist the GDS import.
  • Understand selected layout editing features of Ansys HFSS 3D Layout IC mode.
  • Perform port setup and simulation of a GDS import
Prerequisites:
  • Completion of Getting Started with Ansys HFSS Software course
Please note: These training materials were developed and tested in the 2024R1 release.
    $450.00
  • Course Duration: 1-2 HOURS
  • Skill Level: Expert
  • Skills Gained: GDS File Import in Ansys HFSS 3D Layout (IC Mode), Use of GDS Control Files (.map and .xml), HFSS 3D Layout IC Mode Editing, Interposer Model Setup for Simulation
