Learning Path
3D Design
Advanced Fluid Modeling using Ansys Discovery Software
FREE
4-6 HOURS
3 COURSES
SKU: TBD-DI-00003 Categories: , Tag:
Welcome to the Advanced Fluids Learning Track in Ansys Discovery™ 3D product simulation software.
In this learning track, we will explore real life scenarios, such as how would the fluid heat be transferred over to the solid components and vice versa. We will also see how you can simulate a fluid flow through filters, as the use cases for such simulation are endless, from an oil filter to an air and water filter in various industries. Lastly, we will see a case, where we would need to simulate fluid rotation and its effect on the fluid flow.
This learning track will be divided into three different courses, such as Conjugate Heat Transfer, Porous media and Rotating Fluids (Moving Reference Frames) in Ansys Discovery Software.
Let’s get started!
    FREE
  • Course Duration: 4-6 HOURS
  • Skill Level: Intermediate
  • Skills Gained: Conjugate Heat Transfer, Porous Flow Simulation, Rotating Fluids
