Course
Stratified Flows & Convection
FREE
1-2 HOURS
NPTEL
SKU: BDG-FL-00189 Categories: , Tag:
 width=This course covers the intricate concepts of stably stratified flows, turbulent thermal convection, and flows with vectors. For instance, it begins with the configuration of stably stratified turbulence, where the dense fluid sits at the bottom due to gravity and the light fluid is above. It then delves into the equations for stably stratified flows, explaining the role of gravity and density. The course also explores the three types of stably stratified flows: moderately stratified flow, weak stratification, and strong stratification. The course then transitions to turbulent thermal convection, explaining the system of thermal convection, starting with the internal temperature and how it interacts with the velocity field. Lastly, the course covers the concept of flows with vectors, using examples such as magnetic fields and electric dipoles to illustrate the concept. It introduces the equations used to solve these flows, including the general equation and the equation for vector fields.
This course has been developed by Prof. Mahendra Verma from IIT Kanpur for NPTEL. It is now accessible through Ansys Innovation Space courtesy of the partnership between Ansys and NPTEL, under the CC BY-SA license. For more details, visit https://nptel.ac.in/courses/115104112.
    FREE
  • Course Duration: 1-2 HOURS
  • Skill Level: Intermediate
  • Skills Gained: Turbulence physics, Hydrodynamics
