Tagged: 18.2, General, mechanical, structural-mechanics
April 5, 2023 at 2:32 pm
FAQParticipantSymptom: In SpaceClaim the volume is correct. In ANSYS Workbench Meshing/Mechanical some faces are transparent and the volume/mass is not correct compared to the CAD. The calculation is not influenced. Solution: Inconsistence or mixed up version of ANSYS and SpaceClaim. Delete the ANSYS version folder in the roaming directory (%appdata%), e.g. c:Users
AppDataRoamingAnsys Optional: Clean the registry and or install old ANSYS versions. Updated both to the latest version to solve the problem.
