Why using interfacial anit-diffusion in high viscosity ratio injection simulation show unstable spikes in velocity and pressure field?
Tagged: 18, fluent, fluid-dynamics, Modeling/Setup Advice, MP - Free Surface Flow, multiphase, vof
March 17, 2023 at 1:11 pm
SolutionParticipantPlease see attached document. Keywords: interfacial anti-diffusion, VOF
1. 2048334.pdf
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- What is the superficial velocity in multiphase flows?
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
