April 5, 2023 at 2:31 pmFAQParticipant
It is due to short leg ( in vertical)and long leg ( in horizontal) directions. Had it been equally long legs both the sides, electric fields will be uniform and one can expect close electric field results.
- The LS-DYNA equivalent of *MODEL_CHANGE card (in ABAQUS). Which keywords can be used to introduce(activate)/delete(deactivate) elements in the middle of a calculation (at user-specific time/load steps).
- How to resolve “Error: Invalid Geometry”?
- After Workbench crashes, how can I recover the project from a .mechdb file?
- Model has a large number of contacts – how to reduce them?
