Why the manual thermal conductance value is getting scaled with change in unit system for coupled field analysis?
April 13, 2023 at 7:33 amSolutionParticipant
Please see the attached document.
1. Scaling of input thermal conductance.pdf
- The LS-DYNA equivalent of *MODEL_CHANGE card (in ABAQUS). Which keywords can be used to introduce(activate)/delete(deactivate) elements in the middle of a calculation (at user-specific time/load steps).
- How to resolve “Error: Invalid Geometry”?
- After Workbench crashes, how can I recover the project from a .mechdb file?
- Model has a large number of contacts – how to reduce them?
