June 6, 2022 at 9:57 amFAQParticipant
The command objects can be input to the solvers type like Mechanical APDL, Samcef, ABAQUS etc. Explicit dynamics uses different solver (AUTODYN). It doesn’t support command objects in Workbench GUI.
- The LS-DYNA equivalent of *MODEL_CHANGE card (in ABAQUS). Which keywords can be used to introduce(activate)/delete(deactivate) elements in the middle of a calculation (at user-specific time/load steps).
- How to resolve “Error: Invalid Geometry”?
- After Workbench crashes, how can I recover the project from a .mechdb file?
- Model has a large number of contacts – how to reduce them?
