Why might assembly-level cut operations performed in a CAD program fail to be recognized in Mechanical?
June 6, 2022 at 10:33 amFAQParticipant
The import of assembly-level operations are not supported by most CAD Readers. If the import of assembly-level operations are desired, consider using the respective CAD plug-in geometry interface. Another alternative may be to export the CAD geometry to a neutral format, then import into Mechanical.
- ANSYS DesignModeler: How to Perform a Clean and Repair
- ANSYS Workbench CAD Interface for NX: How To Create Named Selections and Parameters
- ANSYS DesignModeler: Imprinting Geometry
- ANSYS DesignModeler: Weld Feature
- ANSYS SpaceClaim: Shared Topology
- ANSYS DesignModeler: Shared Toplogy
- How to move component within the assembly?
- ANSYS SpaceClaim: Imprinting Geometry
- Bidirectional CAD Interface Between ANSYS Mechanical and Creo Parametric 2.0
- ANSYS Workbench CAD Interface for CATIA: How To Create Named Selections and Parameters
