General
General
Why might a negative angular parameter value in SpaceClaim fail to update during a parametric study?
    • FAQFAQ
      Participant
      The user my report an error similar to the following: “(DP 2) Parameter update incorrect: Attempted = -60, Assigned = 0, Name = Group1” SpaceClaim does not accept negative angular values. You can try defining the angle in reverse direction: (360 degrees – Parametric angular value).
