Tagged: continuous, CYCEXPAND, expansion, graphical cyclic
June 6, 2022 at 9:58 am
FAQ
ParticipantIf you are using a *.db that was saved prior to solving, it will not have duplicate sector info in it. So if you are not doing the post processing immediately after solving, then you need to save the db file and then resume it to do post processing. This should give you correct cyclic expansion.
- How to resolve “Error: Invalid Geometry”?
