Why is the actual coarsening rate so high and the number of radiation elements so low if I am using a discrete transfer radiation model with surface to surface option in ANSYS CFX?
June 5, 2023 at 7:05 am
FAQParticipantThe coarsening rate has no actual meaning when using discrete transfer radiation model without participating media, since no coarsening is applied. When using the surface to surface option, the solver essentially reduces the volume mesh to a “single cell” or a small number of cells. This is why the coarsening rate is so high and the number of radiation elements (“volume cells”) is so low.
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- Setting Operating Density for Natural Convection cases when density is modelled using Ideal gas law
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- In Fluent, how can we reduce the time for an unsteady simulation of a Conjugate Heat Transfer (CHT) simulation? Is there any way to give different time steps for fluid and solid in a single simulation?
