Why is a plastic strain being reported while using an elastic material i.e., *MAT_ELASTIC in WB LS-DYNA?
Tagged: Explicit - LS-DYNA, export, lsdyna, mechanical, structural-mechanics
March 17, 2023 at 8:59 am
FAQParticipantOf course, we wouldn’t expect plastification in an elastic material model. The Vol II keyword users manual mentions this in Remark #3 for *MAT_001. “3. Effective Plastic Strain. The history variable labeled as “effective plastic strain†by LS-PrePost is volumetric strain in the case of *MAT_ELASTIC.”
