Tagged: 19, BCs & Interfaces, fluent, fluid-dynamics, materials, MP - Particle Tracking
May 15, 2023 at 8:32 am
SolutionParticipantSome of the reasons for losing DPM particles or injection locations are explained in Solution#2051182. Besides these, a peculiar issue of cone injections near symmetry boundaries could be the incorrect specification of Azimuthal start/stop angles. Please refer to Sec.23.3.5. of Fluent User’s Guide to get more information on the definition of these parameters. The attached solution provides an example to elaborate the same.
1. 2054800.pdf
2. 2054800.zip
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- How do I use porous media in a multiphase flow?
- What is the superficial velocity in multiphase flows?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
