June 6, 2022 at 9:58 am
FAQParticipant1) The reason to show Force Convergence with “No data to display” — The overall analysis may be straight forward linear analysis and hence no NR iterations. You can quickly check your solution.out file and search if shows anything like FORCE CONVERGENCE. If it does not show it, then you will not get any plot for Force Convergence under solution output.
2) How to get Force Convergence plot: — Go to Analysis Settings//Solver Controls//Large Deflection//On. — With this, you be able to see Force Convergence plot under Solution Output.
