Tagged: 19.2, Ansys nCode DesignLife, fatigue, General, structural-mechanics
January 25, 2023 at 7:34 am
FAQParticipantThe python script used by WE25 is no longer available. WE25 will be removed from future releases. HBM nCode originally introduced load reconstruction using a python and numpy based scripting glyph. This early attempt at load reconstruction was demonstrated in a WE25, but it was not embedded directly in the DesignLife code. In a later release, HBM nCode created an actual load reconstruction glyph and removed the python/numpy script. The load reconstruction glyph is not offered in ANSYS nCode DesignLife.
