March 17, 2023 at 8:59 amFAQParticipant
The discrepancy is due to the joule heating being zero at time zero. Electrical energy equation assumes it is constant over the first time step. The effect of this can be reduced by making the first time step very short. You would see this same effect if you calculated the displacement of a falling object under “constant” gravity. Even though you specify KBC,1, the gravity will be zero at time zero.
- The LS-DYNA equivalent of *MODEL_CHANGE card (in ABAQUS). Which keywords can be used to introduce(activate)/delete(deactivate) elements in the middle of a calculation (at user-specific time/load steps).
- How to resolve “Error: Invalid Geometry”?
- After Workbench crashes, how can I recover the project from a .mechdb file?
- Model has a large number of contacts – how to reduce them?
