Why does the command prompt not clear already executed commands that were pasted from an external program? When pasting a series of commands from, for example, notepad.exe, the commands execute as expected, but the command line isn’t cleared. This can be kind of inconvenient. Can we get it corrected?
Tagged: 17, General, mechanical-apdl, structural-mechanics
May 15, 2023 at 8:32 am
Solution
ParticipantPlease refer to the attachment(s) to access the Solution.
1. 429092.pdf
