Why does a circuit element cause a harmonic piezoelectric analysis to give bad results? If the resistor element is removed, the results are as expected.
April 5, 2023 at 2:31 pm
FAQParticipantCertain circuit elements can produce ill-conditioning, and the presence of any circuit element in ANSYS 11.0 activated a solver setting that may be inappropriate for your model. Solver improvements in ANSYS 12.0 have corrected the problem you are seeing for all circuit elements.
