Why do I get the following error in HFSS Transient when using waveports: “Port refinement, process hf3d error: Port ‘1’ contacts more than one non-conducting material which violates the TEM terminal modes restriction” ?
Tagged: 17.2, Electromagnetics & Electronics, excitations, hfss, Wave Port
February 6, 2023 at 2:42 pm
FAQParticipantCurrently, the transient solver doesn’t support non-TEM mode ports. So TE & TM port modes for waveguides for example won’t work, and neither will quasi-TEM port modes for structures like microstrip lines and coplanar waveguides. Only TEM are supported. A workaround for microstrip and coplanar waveguide structures would be to use a lumped port between the signal conductor and ground. Do this, instead of using a waveport, whose geometry would extend to the air above the microstrip line (and touching multiple conductors), thus supporting quasi-TEM port modes. The lumped port will support purely TEM modes, thus getting rid of this error.
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- How to import/export an Ansys Maxwell model in Workbench?
- How to enable GPU acceleration in Electronics Desktop?
- How to fix messed up Windows layout?
- What are the available boundary conditions in Maxwell?
- Cloud Computing from Electronics Desktop
- How to create and manage a queue of simulations?
- How do I calculate inductance and resistance of a coil in post-processing phase?
- Are solid losses and eddy losses the same in Maxwell?
- Parameters in HFSS 3D Components and design level variables
