Tagged: 17.2, General, mechanical, structural-mechanics
June 5, 2023 at 7:04 am
FAQParticipantThis is a known limitation and we have a workaround for the same as well. See the ‘Result legends’ and its limitation information in Help file ( Copy & paste this link in Help: help/wb_sim/AWEResultsLegend.html ) or go to https://support.ansys.com/AnsysCustomerPortal/en_us/Knowledge+Resources/Online+Documentation/Current+Release/Structural+Mechanics/ANSYS+Mechanical+User’s+Guide?doc_link=/prod_docu/18.0/html/wb_sim/AWEResultsLegend.html. The workaround is, Right click on the legend and choose “High Fidelity” option. This should give you the correct plot
