Why can’t I apply flow out boundary condition to the boundary of a multi-material Euler domain at Y = 0 in an axisymmetric analysis?
June 6, 2022 at 9:58 am
FAQParticipantY = 0 represents the axis of axial symmetry. There is no flow across the X axis due to axial symmetry. Thus flow out boundary condition cannot be applied to the boundary at X axis. User can apply the flow out boundary conditions at the lower I index, upper I index, and upper J index planes in the multi-material Euler domain.
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- ANSYS Mechanical: Node Move
- How can you identify the element types used by Mechanical?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
