Why can’t harmonic analysis results be transferred to harmonic acoustics setup no matter v192 or 2019R3?
Tagged: acoustics, mechanical, N/A, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantPlease close the beta option if you opened. Close the beta option: Workbench>>tools>>options>>Appearance then uncheck [Beta Options]
