March 17, 2023 at 8:59 am
FAQParticipantThe patch for VOF cases by default have the flag “Patch Reconstruct Interface” active. This setting requires that a selected register to patch is correctly defined. This means that for a region register the min-value must be smaller than the max-value for each direction. If this is not the case the patch will not change any value. As a solution use either of the following: a – deselect “Patch Reconstruct Interface” b – provide a correctly defined cell register Keywords: VOF, patch, patching, cell register, region, patch options, Volume Fraction, multiphase
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- How do I use porous media in a multiphase flow?
- What is the superficial velocity in multiphase flows?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
