Tagged: 17, apdl, macros, Macros/Scripting/UPF, mechanical-apdl, scripting, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantUsing a leading comma as a way of repeating the previous command is no longer supported in Mechanical APDL R7.1 and later, specifically in a macro. It will still work outside a macro.
