Tagged: 2019 R2, General, mechanical, structural-mechanics
March 17, 2023 at 9:00 am
FAQ
ParticipantProblem: Possible defect where CAD associativity between ANSYS & SolidEdge is lost. Simply clicking on “Update Geometry from CAD” causes contacts to loose scopings. Answer: This is most likely due to instances. If you import with that option turned off it would likely work better, or import and immediately update before setting the boundary conditions. This is a limitation as of current release (2019R2)
