Tagged: 16.2, dpm, fluent, fluid-dynamics, MP - Particle Tracking, multiphase, Other
January 25, 2023 at 7:17 am
FAQParticipantTracking the movement of particles through the domain can lead to an incomplete fate. A usual remedy is to increase the “Max. Number of Steps” in Tracking Parameters of DPM setup to follow the particles for a longer distance. If this does not change the fate of the particles, a deeper look at the particle velocities may explain why an increase of integration steps would not help. If, for example, the relative velocity between the mill walls of a stirrer and the particles is almost zero, the fate of these particles will remain incomplete. Another possible reason is that the particles are stuck in the recirculation zone.
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Mixing Tank Modeling in ANSYS Fluent
- What is the superficial velocity in multiphase flows?
- Hydrodynamics and Wave Impact Analysis
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
- How do I use porous media in a multiphase flow?
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
