June 6, 2022 at 9:58 am
FAQ
ParticipantThere is frequently an issue with mesh bias because magnetic forces typically are the sum of almost equal and opposite forces. In this case it is possible to do an analysis without one of the parts to get an initial biased solution which could then be subtracted from the solution with both the parts. This corrected solution will produce equal and opposite forces as required.
