Why am I unable to select faces of geometry in Mechanical or Meshing that have been attached from Creo Parametric?
June 6, 2022 at 9:58 am
FAQParticipantThe user may also describe the parts as appearing white colored. This indicates an inconsistent unit system between the Assembly and the component Parts in Creo Parametric. Please make sure that Creo assembly unit system and each part unit system should be same. This requirement is documented in ANSYS/Help as seen under Notations/Length Unit at following link, help/ref_cad/cadProEplugin.html
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- ANSYS Mechanical: Node Move
- How can you identify the element types used by Mechanical?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
