Which unit system is used to input the values from command objects? Does ANSYS solver use same units defined as Active Unit System in the command object?
June 5, 2023 at 7:04 am
FAQ
ParticipantANSYS solver uses the units defined in the Analysis Data Management. Go to Analysis Settings > Analysis Data Management and see the Solver Units. ‘Solver units’ can be set to Manual or Active System. If the Solver Units set to Active System, command object uses the units define as Active system on the top of the command snippet. If the ‘Solver Units’ set to Manual, commands are interpreted using ‘Manual’ units and does not use Active System defined in the command snippet.
- How to resolve “Error: Invalid Geometry”?
